3d-Rendering/Graphics build
Okay, so I need some reccommendations on the pc I hopefully going to get in the future.
So, this Christmas, I'll most likely be getting 2 E5 2665, since they're really cheap, like really, really cheap...
Like $196 AU each, cheap
'ny ways, If you could give a little feedback on this, it'd be great. Thanks!
EVGA SR-X (If I can get my hands on one)
2 x XEON e5 2665
2 x G.Skill Ares F3 4x8
GTX 780 3gb/4gb(Any that's cheap)
Corsair Carbide Air 540 case
2 x H80i CPU coolers
Samsung 840 Pro 128gb
2 1tb WD Green
Cougar GX1050W PSU
Looks great, should be pretty damn quick in rendering. Only thing i would change is the WD green hard drives, thier quality and lifespan can be bad.  I assume you live in Australia, I would go with a Seagate 3Tb,
http://au.pcpartpicker.com/part/seagate-internal-hard-drive-st3000dm001 - I have this one, and performs nice, cool and quiet. And is about the same price as the other two.
Thanks for the recommendation Trevor Strnad. 1tb more for pretty much the same price. Thanks for pointing that out, I would have probably gone with the 2 1tb.
(Trevor Strnad looks a lot like you, like... uncanny)
No problem, if you are anything like me, you will need the space for project files. I am working on a after effects project that spans a full Tb as of today, so crazy.
I had to Google that trevor guy (Im not really into metal..), I can see the resemblance but I think he has a few pounds over me. lol
Yeah, and I need quite a bit of space, I'm currently using over 600gb's of space right now from all my PSD's, PSB's, PNG's and video files. It's a pain because I only have a 1tb right now, so a lot of space will be like heaven to me.
It's cool that you don't listen to metal, metal isn't really that amazing...
