@Mora I was curious if you could tell me what size of table I am going to need to set this thing on... I know the glass heated plate moves back and forth... I just haven't managed to find required operating dimensions.
Thanks
I've had no issues with wiring. My printer is in an enclosure I made, so the wiring is ziptied up & out of the way of everything.
The wires are on the short side, so the control box should really be sitting up around mid printer height- I just used a few blocks of wood to lift it up. This would only become an issue when printing very tall parts though.
As to table size, I use a bench 750mm x1000mm. The bed moves, but stays within the dimensions of the base.
Thanks... after reading I will build a table for it, keeping in mind the height of the controller box. I'm pretty good with wood.
