I recall seeing some 3D printed fan adapters for passively cooled Tesla cards in several Level 1 videos… Does anybody here know if there are existing 3D models for AMD datacenter GPUs? Specifically the MI60 is the one that I have arriving soon and will need cooling…
Actually I guess I’m really after a source for readymade parts rather than just the models, but the models would do in the absence of such a source
Im in the same boat, ordered an Mi100 and looking to 3d print my own fan shrouds. so if no one has posted anywhere keep an eye out and ill get around to posting/creating a thread for my Mi100 plans.
Ordered it through work from our Dell vendor, Im basically seeing how they compare vs the A100 for our ML workloads to see if it would be possible to move to AMD since it maybe cheaper. It should be here by the 23rd and fingers crossed it doesnt get too hot in my Thinkstation if i strap some fans to it whilst i make a fan shroud like i did with my current A100 in the machine.
I haven’t found one for Radeon instinct cards but there are rear mounted io plate shrouds, I would personally use a 92mm fan with a fan capable of at least 3600 rpm 4600 rpm recommend if it’s the sole fan
Oh, interesting. That looks easier to set up overall (as opposed to a blower style fan from the inside of the case). In my case the slots above and below the card I need to cool are in use, though. I may have to modify the model, but this is a great concept.
