Hi all,
I’m trying to get Catalina going properly with the following setup:
Gigabyte TRX40 Designare
Threadripper 3960X 24-core
4x32GB = 128GB DDR4
Radeon VII 16GB
Latest Manjaro on kernel 5.5 (no MCE bug)
I’m currently at a stage that I can use 16 cores and 64GB RAM with decent albeit not native performance, and the GPU is recognized in macOS but as far as I can tell it’s functioning in VESA-mode (no actual hardware acceleration). Also, when booting Manjaro I need to physically disconnect the Radeon VII DisplayPort cable, otherwise Manjaro boots to a black screen which isn’t fixed by unplugging afterwards (I just reboot). I need to plug the DP-cable when in Manjaro for it to boot normally.
I have mostly followed Github kholia/OSX-KVM, but after changing distros from Ubuntu to Fedora to Manjaro I had to start looking around to try to fix problems for GPU and virbr0/tun0 passthrough and such.
I would like to know how the following things:
- How to increase the maximum CPU core count in QEMU to 24 out of 24 (if possible, otherwise highest possible);
- I find it hard to figure out whether SMT is being accounted for, altough it does seem the case even with below config (threads=1);
- Can the maximum system memory be allocated? macOS now seems to think it has 4x16GB installed;
- How to passthrough the Radeon VII fully, as it is functioning in VESA mode now (with or without Whatevergreen.kext in Clover EFI)
- How to fix the need to physically disconnect the DP-cable of the passthrough GPU;
- How to fix virbr0 attached to tun0 permanently, for any ethernet passthrough (currently succesfully using the Titan Ridge AIC -> TB3<>TB2 -> TB2 <> ETH adapters;
I hope these troubleshoot files are enough, but I’m more than willing to supply any other information needed to succesfully complete this project!
lspci -nn -k -D
0000:04:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:66af] (rev c1)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 [Radeon VII] [1002:081e]
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
0000:04:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] [1002:ab20]
Kernel modules: snd_hda_intel
0000:21:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP108 [GeForce GT 1030] [10de:1d01] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GP108 [GeForce GT 1030] [1462:8c98]
Kernel driver in use: nouveau
Kernel modules: nouveau
Note: GT1030 is placed in PCIE16_1, Radeon VII is placed in PCIE8_1. GT1030 is primary UEFI boot device in BIOS.
/etc/modprobe.d/vfio.conf:
options vfio-pci ids=1002:66af,1002:ab20,1022:149c
Note: GPU, GPU audio, USB
/etc/mkinitcpio/conf
MODULES=(vfio_pci vfio vfio_iommu_type1 vfio_virqfd kvm=amd)
BINARIES=()
FILES=""
HOOKS="base udev autodetect modconf block keyboard keymap lvm2 filesystems"
/etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 amd_iommu=on iommu=1 rd.driver.pre=vfio-pci"
Note: I feel the VESA-problem may be related to Grub boot arguments, but I’m not sure.
My boot.sh file:
#!/bin/bash
# qemu-img create -f qcow2 mac_hdd_ng.img 128G
# echo 1 > /sys/module/kvm/parameters/ignore_msrs (this is required)
# NOTE: Tweak the "MY_OPTIONS" line in case you are having booting problems!
# This works for High Sierra as well as Mojave. Tested with macOS 10.13.6 and macOS 10.14.4.
MY_OPTIONS="+pcid,+ssse3,+sse4.2,+popcnt,+avx,+aes,+xsave,+xsaveopt,check"
# OVMF=./firmware
OVMF="./"
qemu-system-x86_64 -enable-kvm -m 65536 -cpu Penryn,kvm=on,vendor=GenuineIntel,+invtsc,vmware-cpuid-freq=on,$MY_OPTIONS\
-machine q35 \
-smp cpus=16,cores=16,threads=1,sockets=1 \
-vga none \
-device vfio-pci,host=04:00.0,bus=pcie.0,multifunction=on \
-device vfio-pci,host=04:00.1,bus=pcie.0 \
-device vfio-pci,host=47:00.1,bus=pcie.0 \
-device vfio-pci,host=47:00.3,bus=pcie.0 \
-usb -device usb-kbd -device usb-tablet \
-device isa-applesmc,osk="ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc" \
-drive if=pflash,format=raw,readonly,file=$OVMF/OVMF_CODE.fd \
-drive if=pflash,format=raw,file=$OVMF/OVMF_VARS-1024x768.fd \
-smbios type=2 \
-device ich9-intel-hda -device hda-duplex \
-device ich9-ahci,id=sata \
-drive id=Clover,if=none,snapshot=on,format=qcow2,file=./'Mojave/CloverNG.qcow2' \
-device ide-hd,bus=sata.2,drive=Clover \
-drive id=MacHDD,if=none,file=./mac_hdd_ng.img,format=qcow2 \
-device ide-hd,bus=sata.4,drive=MacHDD \
-netdev tap,id=net0,ifname=tap0,script=no,downscript=no -device vmxnet3,netdev=net0,id=net0,mac=52:54:00:c9:18:27 \
-monitor stdio \
Clover configuration is iMacPro1,1 supplied (but updated) Clover version and drivers. Kexts:
(optional) Whatevergreen.kext
AppleALC.kext (not yet configured any audio)
AppleMCEReporterDisabler.kext (known to prevent kernel panics for AMD-based Hackintoshes)
Lilu.kext (master of Whatevergreen, AppleALC)
Like I said, if anything else is needed, please do let me know. I understand I’m asking many questions at once, so my primary concern would be GPU/CPU passthrough, networking and minor issues like cabling coming last.
