3770k refuses to OC
I have tried it and tried it over and over and i cannot get my 3770k to OC i have followed a guide to get a stable 4.6GHz but everytime i try and get it to work my cpu never OCs. and i have a Z77-V Deluxe so i know its not my board. what else could be causing my cpu not to OC?
Or what is the best settings to get a stable OC for this cpu? (preferably in the mid 4s)
Try 4.4 and 4.5, 4.4 is almost a given on all 3770ks.
I was running an ez 4.2GHz at stock voltage on my 3770k before my mobo broke and had to rma. Hopefully this week i'll be able to get my replacement and try a better OC.
Increase voltage. Better cooling. is it overheating? what cooling do you have?
push pull config with delta fans on a H100
and it isnt even unstable i set all the settings the way it says to in BIOS and it just says it runs at the same stock clock. i have tried over 10 times now and all just read stock clock.
