3770K Overclock help
Hey guuys I just used MSI OC Genie II to overclock my 3770K, here are my results:
Idle:
[url=http://www.flickr.com/photos/[email protected]/8289073374/][img]http://farm9.staticflickr.com/8354/8289073374_d8d901080d_b.jpg[/img][/url]
[url=http://www.flickr.com/photos/[email protected]/8289073374/]Screenshot (2)[/url] by [url=http://www.flickr.com/people/[email protected]/]warrenjflick[/url], on Flickr
Prime95 small FFT:
[url=http://www.flickr.com/photos/[email protected]/8288014209/][img]http://farm9.staticflickr.com/8214/8288014209_4c9df55eeb_b.jpg[/img][/url]
[url=http://www.flickr.com/photos/[email protected]/8288014209/]Screenshot (3)[/url] by [url=http://www.flickr.com/people/9085[email protected]/]warrenjflick[/url], on Flickr
How much farther do you think I can push it?
I'm surprised you got it this far. I couldn't.
I tip my hat to you.
Nice. I also have mine at 4.2GHz with the H100i and our temps are similar. 60C isn't a bad load temperature so you could try to push it to 4.4 or even 4.5GHz.
You should be able to get it up to 4.6Ghz (assuming most reviews aren't getting crazy chips that overclock really, really well, which could definitely be the case when Intel is providing th CPU to the reviewer).
Don't waste your 3770K and push it a lot farther than what you have now. Plus you have a H100 cooling it so why don't you put your cooler to better use too. I recommend you try to push it to at least 4.8ghz. Set your CPU voltage to at least 1.35v and run Intel Burn Test because it is more stressful than prime 95. Run that and then come back and post your results on how it went. If all goes well and you have not reached the 105C point yet, try to shoot for 5ghz
