3700x 4x16 GB investigating Machine Check Exceptions
My new system is configured with the following hardware:
  • 3700x
  • Asrock x470 Taichi ultimate
  • 4x 16GB Samsung OEM B-Die ECC 2666 mhz
  • 1TB m.2 SSD
  • Seasonic 650 watt psu
  • XFX rx480
From the get-go the system had boost issues, mainly due to voltage scaling aggressively with boost which caused the Wraith prism cooler to struggle which in turn caused the clocks to go down a lot.
It was and endless cycle, at the moment I am running manual settings, these settings where 32 hour memtest stable, multi hour cinebench stable and survived multiple hour gaming sessions while I ran windows to test and tune the system.
Now the system is running Debian 10 Stable for about a month without issues until yesterday, I experienced extreme slowdowns and mouse lag and a minute later the system rebooted.
Checking the logs revealed MCE errors, and I am researching the cause since I modified a lot of stuff in the system and downvolted a lot of components to keep noise and temperatures in check.
At first I suspected the GPU since I modified the BIOS to run a downclock and aggressive downvolt but after examining the logs I am starting to suspect the CPU/memory, I raised the CPU voltage a little from 1.275 to 1.285.
Memory is still running at 1.21 volts stock speeds, I have not been able to tune that.
kernel: [    0.570196] mce: [Hardware Error]: Machine check events logged
kernel: [    0.570196] mce: [Hardware Error]: CPU 6: Machine Check: 0 Bank 5: bea0000000000108
kernel: [    0.570196] mce: [Hardware Error]: TSC 0 ADDR 1ffffb5a5b668 MISC d012000100000000 SYND 4d000000 IPID 500b000000000
kernel: [    0.570196] mce: [Hardware Error]: PROCESSOR 2:870f10 TIME 1581203104 SOCKET 0 APIC c microcode 8701013
kernel: [    0.574248] mce: [Hardware Error]: Machine check events logged
kernel: [    0.574257] mce: [Hardware Error]: CPU 8: Machine Check: 0 Bank 5: bea0000000000108
kernel: [    0.574259] mce: [Hardware Error]: TSC 0 ADDR 1ffffc036664a MISC d012000100000000 SYND 4d000000 IPID 500b000000000
kernel: [    0.574262] mce: [Hardware Error]: PROCESSOR 2:870f10 TIME 1581203104 SOCKET 0 APIC 1 microcode 8701013
kernel: [    1.709233] amdgpu: [powerplay] Error in phm_get_clock_info
I have just installed rasdaemon but I have not experienced a new crash since increasing the voltages so ras-mc-ctl --errors show no errors.
Basically I am wondering where to focus my research, I suspect ram should be first since 4x 16GB can put quite a strain on the system.
Update:
I’ve reset the uefi to defaults and run the cpu in eco mode with a minor offset now. No new machine check exceptions have been reported in the past few days.
CB 20 performance is comparable to stock settings but temperatures are way lower (about 10deg)
Boost speeds are almost equal peak all-core boost is a little lower at 3.9 Ghz however this is a sustained boost with the cpu mostyl sitting between 65 and 70 °C during 20 minutes of CB20 MC.
With default uefi settings the CPU would do all core boost past 4.2 Ghz however to do this it would ramp up the voltages causing insane heat (60 deg > which in turn caused the boost to drop down to 3.8 Ghz there it would get some thermal headroom and try the same boost cycle again. This resulted in 4600 CB 20 MC score which is almost the same as the 4550 I am seeing in ECO mode.
This confirms to me that the UEFI on this board still has some issues with voltage control and boost, there is a new version (3.90) with latest Agesa patch but that version has some weird bug where machines cannot boot after being shutdown so I will wait a bit before installing this.
Tl;dr:
If you experience thermal/boost issues on an asrock x470 board try running the cpu in eco mode, my single core performance stayed the same (~500) and multi-core showed a slight drop but thermals and noise are way lower in both scenarios.
Interesting. I thought eco mode was just a limiter for high tdp chips to run in a 65W power budget. Might try that out on my 3900X.
That is what it should be, based on the description in the UEFI my cpu is now targetting 65W package power. They also mention 45W on the same uefi page, this might be for cpu core power (SVI2) .
Basically the default settings on the x470 taichi ultimate seems to supply auto OC voltages for PBO to the CPU with PBO enabled (auto OC disabled). This makes the chips agressively target higher boost but it does not have the thermal headroom with the stock cooler. Now by enabling eco-mode on a 65w TDP part it shows a lot more conservative behavior. I suspect that the multicore performance on your 3900X will suffer more with ECO mode. What board and cooler do you have and are you experiencing major boost/thermal issues?
I can get better benchmark scores (~5150 CB20 MC) and thermals with a manual OC however due to the reports of chips degrading at voltages lower than 1.3 volt and my machine showing increasing amount of MCE events I ditched the manual OC.
that is running the 4.19 kernel from what I can see
Have you tried running the latest kernel to see if it fixes issues?
4.19.98-1 indeed, I did not run a newer kernel.
System runs root-on-zfs so I try to stay on the Debian Stable kernel just to keep my life simple :).
I run a dual boot system and did most of my testing on windows just to be able to validate my results against others and also used windows to validate my findings regarding ECO mode.
Cinebench R20 does perform a little better in Windows I run it through Wine 4.0.3 on Linux, the difference is about 10 point in single core, 60 in multicore.
I have been seeing a lot of issues getting fixed for AM4 with the latest kernels. Not sure if that is something you’re interested in trying, but it might be worth it.
Just recently I have seen a lot of stability improvements, but to be clear, i have also read about some folks having issues with certain things like touchpads not working or wireless cards pooping out.
