360mm rad for 780sli and 4770k?
so i have a nzxt h630 i just moved into, currently i have an h80i on the cpu and the 780s are stock cooler varieties. however the motherboard i have is a vi gene (amazing board by the way) due to the spacing of the pcie slots the graphics cards are pretty close and I'm beginning to look at water cooling more seriously just because i want the gpus to run cooler. i would have moved motherboards but seeing as now i have a working hackintosh which took some work i don't want to change the system configuration.
so the question is this. i have space to put a 360mm rad in the top with one set of fans in either push or pull so is a 360mm rad enough to cool 2 gtx 780s and a 4770k (not over clocked at the moment due to osx not playing well with over clocks)
what rads do you suggest and i already have 3 corsair sp 120s with pwm so should i use those (I'm willing to spend some money to upgrade to some noise blocker enloops if somebody can say there better) already have a swiftech m655 and will need a rad.
No takers?
With no oc a 360 rad will be fine,
SP120s are good radiator fans no need to buy something else.Configure them to push air out of the case.
ok thankyou, i don't plan on over clocking how do you know? experience? what if its a 30mm thick rad?
120mm of rad space per component. 120mm of rad space for overclocking headroom per component.
It's just a widely recognised rule of thumb.
30mm is sufficient, but it isn't the thickest radiator you will see. You will be absolutely fine at stock speeds.
Sure, with a thick enough rad, and decent fans, a 120.3 is plenty. Would I recommend a 120.4? Probably, because your case has enough room for a lot of rad, but that isn't terribly necessary with out OCing. Cutting it close, though. You have to remember that GPU Boost 2 automatically OCs, though. Since you are running two 780s, and they are most likely overclocking to the 1150+ range, I'd definitely go for a total of 480mm of rad. However, if they aren't oveclocking that high, then don't worry.
30m thick means that the radiator is 30mm thick; pretty average, even a bit closer to the slim side. For comparison, the Monsta series from Alphacool are 80mm thick, and are insane.
So, basically, depending on the GPU Boost you are getting, a 120.3 might be fine, but a 120.4 is ideal.
i went with a 360mm monsta! lol should be fun im putting corsair sp 120s in push pull pwm edition and running them from a swiftech pwm spliter. i also went with swiftech blocks for the gtx 780s and a raystorm for the cpu block i think that should be good. iv opted to remove the drive cages and break out my dremmel to fit that rad in the case, i figure long term it will be worth it because i dont really need 3.5" drive cages i swiped 3 seagate 240gb ssds planning on getting some raid 0 on. :)))
