Those a great temps, especially for the IntelBurnTest, as that Loads up a CPU and generate more heat than any program in real world use ever would, same goes for prime, if you want you could go to 1.4v and push it a little higher, as 80-85c is where you shouldnt go past for Intels, but if your at 71 stress testing you definitley have headroom.
