all the OC sites are saying 1.50v. But TBH that still a guess. IMO I would not go over 1.40v for a 25/7 OC. Also I know its prime stable but have you checked for WHEA errors?
Its ok with these chips to have stepping with an OC. Why have it at 4.8ghz while surfing the web? I am down to like 1.6ghz while web surfing an 0.99v-1.08v an @ 24c-26c. Volts in the end is whats kills the life span of chips.
As far as WHEA erros go. Its easy to find them while using p95 if your OC isnt a 100% stable. Instead of p95 crashing like it would on a SB chip it recovers be for it can crash so you get it to pass p95 an seem stable. But its really ALMOST failing or I sould say it failed but recovered so P95 never saw it fail. TBH really little info on WHEA errors.Some ppl are running there OC with them an not caring others are backing the OC down an uping the volts to get rid of them. WHEA errors seems to pop up when there is not enough volts for the OC. IMO from what little info there is if you have WHEA errors then you not a 100% TRUE STABLE. Again this is just what I like to go by.
Hey I would leave it at 4.8ghz just like the others mentioned. Set your voltage at 1.35v I am pretty sure it will be stable. I have my 3770K running at 1.35v. Also just know about temps our CPUs MAX limit is 105C so don't get too worried about being in the 80s.
Hey if you really really really want to know if your system would be stable, I recommend you run 10 runs of Intel Burn Test. That test will certainly kill your system. It is much more stressful than Prime 95. If you can pass Intel Burn Test, you can past anything.
Also what motherboard are you using? I want to know so I can take a look at your BIOS and see what features you have to help you with your OC. Also what CPU cooler are you using as well?
Intel Burn Test download: http://majorgeeks.com/IntelBurnTest_d5987.html
1.4v isnt bad for 4.8ghz but again I would not want to run 1.4v 24/7. But I guess if your going to upgrade your chip in two years high volts wont matter for you.Rumour has it 1.5v is max for IB. I stress RUMOUR.
