hey guys, i currently have the i5 3570 (not k model) and i was wondering what should i overclock it too if i do, and how do i overclock (ive never overclocked anything before) my cpu cooler is the xigmatek Loki.
any help would be awsome! Thanks in advance.
-Matt
Ummmm, I thought that only 'K' Intel processors could be OC'd?
They can still be overclocked but it is a lot more limited than unlocked "K" series models.
If you're doing a small OC then you'll be fine. If you're looking to do anything major, you might want to look into other cpu options.
