350W PSU, nuf' to keep my temp. pc running?
Will my 350W PSU that came with my current computers case be enough to power this:
Asus M2N nForce 430 mobo (also, will that mobo fit with my other parts?)
AMD Athlon 64X2 4200+ 2.2GHz
2GB 800MHz RAM
GeForce 9600GT 512MB
I think the case has 1 12cm fan. Maybe 2.
no, you need at LEAST 400 watts..
Yeah that would be pushing it...especially if your using a cheapo. I had a cheapo 400 watt that had a hard time with a Athlon 64 3500, 1GB DDR 400 Ram, and a 7800 GT. I put a second hard drive in it and it just pushed it over the edge lol. So yeah, 350 might have a hard time.
So, should I go for a new temporary PSU, or should I buy the PSU that I'm going to use for my future main build?
might as well get the PSU you're gonna use for your main build otherwise you'd just be spending more
But wouldn't that get kind of hot?
Maybe? Depends on what your planning on getting. The heat shouldn't really effect your components much though considering the fact the PSU just exhausts out the back. Thats what I did though, just bought mine for future proofing. Its a Thermaltake Toughpower 850 watt...I don't even come close to requiring that much on my current build, but it will eliminate me having to spend even more money on a new PSU later.
And if your wondering, I love my Thermaltake Toughpower. Its extremely silent, and I have had whatsoever no trouble with it.
knowing case psu's, no it will not work. I would shoot for maybe 400 wats of a good quality psu
This is the final build:
http://pici.se/pictures/DTqghbyuk.png
Looks good...dont forget the other stuff...CD/DVD drive, Hard Drive, Operating System, etc.
My head almost exploded when I saw those prices, but then I noticed the foreign language hah.
probably will not, unless its a brand name psu with like a peak wattage of 400 or something, see that it came with a case its probably generic, and im 100% sure it will not work or work propely
Man I'd at least get a 550w. A 350 sounds wimpy
Well i mean if ur seriously on that big of a budget, just go to any computer store n buy a generic 450W psu it only cost like 10 bucks, it will work. i've tired before on almost indenitcal setup.
I already have a HDD with XP installed etc.
if it were me id go atleast 600 cause more expandability
I'm going 850W.
