£350 mini/micro pc
I've been asked by my mother to build a PC for my little sister and herself for occasional use of internet and just the little games my sister plays.
The build is based at £350 no more than £450 as I am paying for the "extras" as I want them to have a long life pc with options in the future to build upon.
I have a idea already in my head what I want to build with;   http://uk.pcpartpicker.com/user/walkingdead431/saved/3fmV
I like opinions on the build and if known where I should cut components out for cheaper build, but keep in mind I want long life out of this as for them not to spend more money in the future.(reason for build is that my sister has a crap laptop that is unbelievably slow and is falling apart literally, only 2 years since bought..)
thanks
http://uk.pcpartpicker.com/p/2sfKH
£459.83
If you don't want the dvd/cd writer it fits in budged just fine. You might want consider a network card. If you need one have a look at the ASUS PCE-N15 (make sure it the PCI-slot is compatible with the motherboard).
Good luck picking parts and building. I hope this was helpful in some way.
klarkie,
You can do a lot better than that!
http://uk.pcpartpicker.com/p/2sgho
You could choose a cheaper motherboard. But the integrated wifi could be useful.
The Athlon is just an A10 APU with the graphics turned off. It will not bottleneck the 7850, and you should be playing a good number of games on high or ultra at 1080p.
Even if you don't require this for demanding games, something like this is much better bang for buck.
Glad you came back to post pictures. People been complaining that people don't take pride in their builds. Enjoy it
Thanks, this little build is for my mum and sister. I think she will start gaming a little on it also.
Interesting that you put your PSU facing upwards.  I put mine downwards.
Any particular reason why you oriented it like so?
Actually never realised I done that :o I was so stressed and annoyed that Amazon had sent me the non modular version and not the semi modular that I was more intent on getting the cables managed better, but anyway the air flow in the case was pretty nice and breezy I think it might of been a better solution this way up. the fractal node 304 has a dust filter mesh on the bottom so that's pretty much wasted on it :(
Nice little APU build. I have the same case (black) and love it. :)
Doesn't really matter which way you have the PSU facing. It exhausts the hot air out the side anyways.
