3470 or 3570k
I have £300 to spend and from my previous thread I have decided to go with intel rather than AMD due to the increased single threaded performance and the fact that I have a few games that will only use one core (Sins of a solar empire for example).
I need a new CPU, Motherboard and PSU. I could also do with some RAM though If I buy a cheap 1GB+ stick of DDR3 for my HTPC I can reclaim the 4GB DDR3 currently inside that.
Now the motherboard I want (ga-z77-ds3h) costs £68 and the psu I like the look of (corsair 430w cxm) costs £39 leaving me with £193 for CPU & RAM. Now if I go for the 3570K at £173 I will only have £20 left for RAM so I will probably buy a cheap DDR3 2GB stick for my HTPC to use the 4GB from inside that until I can get some money together for an upgrade.
However if I buy the 3470 for £145 and choose a motherboard with a B75 rather than a z77 due to not needing overclock capability I would be able to afford 16GB 1866 Kingston CL9 Beast series.
Eventually I plan to buy an SSD which is why I want 16GB RAM ideally so I can safely disable the pagefile however I wont need this amount of RAM until I get the SSD really.
Which should I go for?
More RAM and a slightly slower CPU but without OC capability?
Or faster CPU with OC capability but crippled RAM for now?
If this helps I dont actually plan to OC now (will be stuck on the stock cooler for a few months anyway) or even in the near future but depending how long this system lasts I may want to OC towards the end of its life to get a few more months out of it. I generally keep my builds for 2 - 3 years. Though I tend to upgrade partially every 6 - 12 months so SSD, H80 or Havik 140 (& RAM if I go with the 3750K) will probably be in 6 months followed by a new single GPU to replace my crossfire 5750s 6 months after that.
Just get a cheap 4gb ram kit that is like 1333mhz now for your htpc and go for the 3570k and a overclocking ready motherboard,
I have the 3470 and it works just fine, great for gaming. I went withit for 2 reasons over the 3570K - 1) Cheaper 2) Don't want to overclock.
I'd go with the 3470 and get the other parts unless you like to OC.
So one for the 3470 and one for the 3570. Anybody want to be the tiebreak?
I have the 3570k and i recommend it, brilliant core, my friend has a 3470 and i get a little bit better performance than him.
Thanks, is the performance difference enough to justify spending 15% more on the core and getting by on 4GB of RAM instead of 16GB?
i dont really know, we never really compared our framerates, although I'd just like to say that 16gb of ram is a lot just for gaming, i have 8gb and i almost never use half of it.
Okay the decision made itself in the end as I managed to get everything I wanted (3570K & 16GB of RAM) with the motherboard and PSU I wanted I got £70 off after a special offer. Getting it delivered on tuesday morning so that can't come soon enough.
