what do you guys think any good?
- AMD Athlon 750K 4.0GHz Quad Core CPU
- 8GB of 1333Mhz DDR3
- RAM1TB Hard Drive Storage
- SpaceRadeon HD 6450 2GB Graphics
- GA-F2A55M-DS
- Shark Gaming Case & 450W Basic
I'd go this way http://uk.pcpartpicker.com/p/2rN5M
http://uk.pcpartpicker.com/p/2rOj2
You only need 4GB of RAM for gaming. You can add another 4GB later.
This build costs a total of around £340, but it contains a 7850. Worth it if you can save up the additional funds. The 7850 will play a good number of games on high/ultra settings at 1080p.
Ensure that you grab an A75 chipset motherboard or greater. This will grant you USB3 and 6GB sata for SSDs.
ALWAYS! grab a good PSU like the XFX unit. Never use a no-name brand unit, they will damage your components.
And always use a 80 plus certified or greater power supply. :)
thanks for your help
