What sort of video editing will you be doing? With what programs (and versions of those programs)?
I've made some substantial adjustments, based on what I feel would work best for editing, etc., but without more information, these tweaks may not be quite as useful.
http://pcpartpicker.com/p/3krUs
Swapped to Intel and a rather strong Core i7 because of its reputation for editing.
Changed the CPU cooler to something that's less likely to have issues with fitting with all the other parts.
Swapped motherboard because of the processor change.
Upped the RAM to 32GB. My mom does video editing and, with After Effects, for example, regularly bleeds into the 28-29GB range of RAM use,
Scrapped the Corsair SSDs in favour of a higher capacity Samsung EVO.
Greatly upped your storage--if you're working with video, you'll be munching through it like crazy. You could even jump up to WD's 4TB drives if you were feeling crazy, but that may be overkill. One for regular storage, one for overflow/scratch disk.
Changed the PSU to something far less overkill.
Scrapped the WiFi adapter as the Motherboard in the new build has integrated WiFi.
Dropped the video card down a few notches. I feel that the bleeding edge of video cards is overkill, but you can do whatever you feel like spending that cash on, I guess.
Just my 2 cents.
