http://pcpartpicker.com/p/Zz3B
build is for gaming, rendering , livestreaming , and using sony vegas for youtube.
also another question how much could money could i make off bitcoin with this machine.
if you know something better then this build post it
thx
Looks ok..
If you are lucky single HD7970 hash rate is about 600..
http://pcpartpicker.com/p/Zzzc what I would get, but its not too different both are good
Im $30 over but for what u get it is EPIC and fit your suit perfectly.
http://pcpartpicker.com/p/ZAZV
-MIxchew
nice build :)
i think staying away from crossfire is better because of it problems you might have with your cards >_>
having 1 strong now then sli/crossfire it later will be better and cheaper
what about this http://pcpartpicker.com/user/saudivip/saved/1DN3
Stampy
6
