$300 MineCraft Rig
Guy at work asked if I could spec out a rig for his kid for about $300 USD I have speced it out so that it could be upgraded later with at GPU and more Ram I went with AM3+ so that an 8 core could be dropped in later if he wants.
I just want have you guys check my work and let me know if the Onboard GPU is going to absolutely blow out of the box. I think it should be OK for Mine craft
http://pcpartpicker.com/p/tHtrpg
 Thanks in advance,
That's a bit sketchy.  Minecraft likes stronger single cores, and that onboard video is probably only good enough to push out a picture.
http://pcpartpicker.com/p/ysQh23
@OP If the build is strictly for MC then go with this ^
I recently upgraded my graphics card and I saw no improvements on Minecraft (even with shaders) It's the CPU bottleneck
 http://pcpartpicker.com/p/DwQh23
Mine craft will play on a potato so power really isnt in issue, however I suggest the above. Why? because its cheaper and performs better than your suggestion
And by the time some small kid who wants to play mine-craft needs an upgrade, he should just go with a new cpu/mobo/ram/gpu combo as ddr3 wont be mainstream and fx 8350's probly will not be sold as new parts.
Plus the energy savings will practically pay for the computer!
My potato laptop doesn't like minecraft tho :C
Thanks for all the Input guys! Im going over all the options with him now.
Thanks Again.
