300 - 350 dollar build using this webiste?
I want a steambox kind of build, I won't be using it like a steambox (Pluging it into a TV, It would sit like a normal desktop PC so no need for a small case) I want it to be able to play Amra 2, Far Cry 3 and BF3 on like 30fps med grafics and highest res possible. If you could use this website http://www.pccasegear.com   or any other Australian website.
http://au.pcpartpicker.com/parts/partlist/
Wow Australia is a rip off!
You can get an A8 if you really must
Could you make a build for me please?
I have...follow the link...
I just get their main page with Austrlia seclected, could you re link it?
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor ($129.00 @ PCCaseGear)
Motherboard: Asus F2A55-M LK PLUS Micro ATX FM2 Motherboard ($69.00 @ PCCaseGear)
Memory: Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 Memory ($29.00 @ Foxcomp)
Storage: Western Digital Scorpio Blue 320GB 2.5" 5400RPM Internal Hard Drive ($49.00 @ PCCaseGear)
Case: Cooler Master Elite 430 ATX Mid Tower Case ($49.00 @ PCCaseGear)
Power Supply: Silverstone Strider Essential 500W 80 PLUS Certified ATX12V Power Supply ($59.00 @ PCCaseGear)
Total: $384.00
if you're only running an APU that psu is way overkill, unless he plans on getting a discrete card later.
for now you can get away with a Seasonic 300W 80PLUS bronze for less ($44) [http://pcpartpicker.com/part/seasonic-power-supply-ss300etbronze]
