30 inch Monitor recommendations
Since my 27 inch dell u2711 seems to surrender it's service (blue dots in certain grey tones, on the first DVI port it's unbearable and it also starts on the second one aswell) I'm thinking about getting a new one, and up to 30 inch this time. I really liked my current dell monitor so I was thinking of getting the newer 30 inch version of this one the u3014 I believe, but 1000 bucks is kind of expensive so I wanted to know if anybody knows a cheaper alternative to the dell one?
Specs I need:
60 herz
30 inch
IPS (preferred)
1600p resolution
So any recommendations?
Honestly.. your not gonna find much under a 1000 but hey the HP Z30i 30" is prolly the only one i do know that you can get for about 900 dollars...
How about a FW900? It will do 2560x1600 at 72Hz and has better color, contrast, and viewing angles than an IPS. It can also do 1920x1200@96Hz or 1536x960@120Hz. The only issue is that it is only a 24".
I'm using ZR30w 's, I like them, they're discontinued now but you can still find some out there.
Yea I know it's weird, I can't get decent 30 inch monitors for less than 1000, but I can get a 4k IPS monitor with 27 inches and 60 herz for 650, it's just really really weird, one should think that it is much more difficult to get a higher pixel density.... thanks anyway
It's because the 4K monitors are cheaper to make as there is more demand.
