3 Monitors; [Solved]
Hello everyone,
Im in a pretty big pickle with this one and I thought where better to come than the Tek forums as you guys seem to be the most experienced with dragons, computers and what not.
I recently picked up 2 VGA monitors pretty cheap on a local trade website and they are both working fine, I have a standard HDMI with my rig of course but I was just wondering how I could extend the desktop to the both of these monitors and have my main desktop with task bar on the HDMI one? I seem to be able to get the 2 screens working at once but never 3. I have a AMD Radeon HD 5850 currently with the HD cable connected to the main, and a VGA to DVI running into the two DVI ports, I also recently purchased one of these;
http://www.amazon.co.uk/Sapphire-44000-02-40R-Active-Display-Cable/dp/B00433C5Y4
As I was told by a friend that if I used 1 DVI port and 1 Display Port this would work, but either I can't figure how to configure it or that method does not work. To add I don't really wanna game across 3 monitors, it would just help with the work I do to have these extend the desktop.
Well hope you all can help. Thanks in advance from the Emerald Isle,
Dan.
Thanks for the response.I managed to try what you said but sadly with no joy.
I did figure out what caused it however, it seemed that because I as using a VGA monitor, with a VGA to DVI cable going into a DVI to DP adapter it was not sending the signals correctly. So I went on and purchased a VGA to DP adapter from Amazon which worked a treat, so all 3 screens are now working, I made sure to pick up a 'Eyefinity compatible' adapter however. This is it;
http://www.amazon.co.uk/gp/product/B003HC85D2/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Thanks again for the help anyway! :)
