3 monitors on 560ti?
Kay, simples, i need  to know whether i can run 3 monitors at all from a 560ti (2DVi and 1 HDMI)
http://www.asus.com/Graphics_Cards/ENGTX560_Ti_DC2DI1GD5 (this one)
I'm planning to upgrade in the near future for a r9 280x or similar but the monitors ive seen on sale end within 3 days so need help asap
Thanks,
Me :)
You can only use 2 monitors (2xDVI or DVI+HDMI), i've got the same card and tried it aswell. Mabey you can run 2 monitors from graphics card and 1 from the igpu.
The max resolution is 2560 x 1600, if that helps
