Continuing the discussion from The Lounge :
I've got this monitor, and am wondering if I can mount this on a regular 100x100 or 75x75mm vesa mount. It appears that there are three holes, and some googling brings up that this monitor(Hyundai Imagequest L70S) supports vesa mounting.
Marten
April 23, 2015, 6:42am
2
Well its not a VESA mount as that is a standard and has 4 holes. Perhaps the manufacturer has and adaptor plate to goes to a VESA mount.
If the 3 holes are threaded and your a bit of a handy man use could make a plate yourself fairly easily.
From what I can see it looks like the monitor merely has the VESA mount at a different orintation.
Whats the distance between the mounting holes? Could be something as simple as only using three holes and changing orientation of the mounting plate?
This I bet that the 4th hole is behind that sticker and just needs a screw to be poked through it.... Looks like a 75mm or 100mm VESA on its side.
Never thought about that. I'll check on it.
~102mm across. okay.
Peekaboo, I poked a hole in the sticker.
x = 102/sqrt(2) ~73mm, so 75x75mm in a diamond orientation.
Thanks for all the help!
