2x2 DP 1.4 KVM (10g usb) various issues resuming from sleep/power off
KVM Model:
SQ1007387 - 1.4 Display Port KVM Switch - Dual Monitor - Two Computer
10-gigbit
Problems:
  1. On System 1 (MacBook Pro 16 M3 Max) the main monitor wrongly gets detected as only 4k@60Hz capable when System 2 is off.
    • To recover I have to turn on system 2, toggle over and detect it there, and then switch back to System 1. It then detects it as 4K@144Hz (which is highest M3 mac can support as I understand.)
    • Fairly consistent. Appears to happen every time I switch to the MacBook when the other system is off.
  2. The USB devices connected through the KVM (both USB3 ports) sometimes lock up.
    • Sometimes all USB devices lock up, and then I have to power cycle the KVM to recover.
    • Sometimes only the Logitech G910 keyboard locks up, and then I have to re-plug the keyboard to recover it.
    • Not consistent. Happens maybe 50% of the time when either system has been off for some hours.
  3. On System 2 (Windows Desktop) Sometimes when I resume from power off or sleep my MSI MPQ 274URF QD main monitor (running 4k@160hz HDR) has problems turning back on. My secondary monitor running 4k@60hz non-HDR resumes fine.
    • This can usually be recovered by by simply toggling input select button twice. Rarely I need to power cycle the KVM.
    • Fairly consistent as long as System 2 is already selected while it is powering on. Feels like 90% of the time.
Any hope of fixing these issues? Or suggestions to better manage/isolate them?
Other Notes:
Some possibly relevant system specs:
KVM cables and devices:
System 1 (MacOS laptop):
  • MacBook Pro 16" M3 Max → Thunderbolt 4 3ft cable → Belkin “Thunderbolt 4 5-in-1 Core Hub”
  • Monitor 1 cable: Moshi USB-C to DP Cable 5ft (previously Club3d, no difference)
  • Monitor 2 cable: Club3D CAC-1557 USB-C to DP 1.4 6ft
  • USB cable (hub to KVM): Thunderbolt 4 3Ft cable
System 2 (Windows Desktop):
  • MB: Asus ProArt B550-CREATOR
  • GPU: Nvidia RTX 3090 (G-sync enabled on both monitors)
  • Monitor 1 cable: FIBBR 2M DP 1.4 (previously Club3d, no difference)
  • Monitor 2 cable: ConnectPro VESA Certified DisplayPort 1.4 Cable 6ft
  • USB: MB USB 3.2 Gen 2 port → 6FT usb3 A to C 10G data cable → KVM
Sleep issues are usually either settings or GPU driver-related. First thing I would try is running DDU:
Then reinstall Nvidia drivers from their official page:
On the MAC, I know there use to be a sleep-related bug. Can you disable sleep in the settings for testing?
Have done some additional testing.
For the MAC when sleep is disabled and I don’t shut down, it stays stable.
I did try simple full shutdown on the mac and power on. It has similar issues. Either Monitor 1 is wrong resolution or fully not detected. Sometimes they will come back after a KVM toggle, but I usually have to re-plug the thunderbolt hub to the mac and sometimes then toggle the switch 1 more time to get it back.
Edit: forgot to mention. Also I did DDU on the PC. It still behaves the same. It recovers pretty easily so I am less concerned about this one, just a bit annoying.
@Level1_Amber Just to update here. I switched to a different USB hub (Monoprice SuperSpeed 4-Port USB-C Hub) over a week ago and have not experienced any USB lockups since.
Also, turns out that switching to the Moshi USB-c to DP adapter allows me to not have to turn on the PC to get the mac to properly detect Monitor 1. It still usually detects the wrong refresh on boot or resume from sleep, but now I only have to toggle the switch 1-2 times to get it right. I don’t have to turn the PC on.
The PC still usually does not detect Monitor 1 on boot/resume, but 1 toggle brings it back.
Open to any suggestions on improving Monitor 1 detection without needing to toggle.
@wendell any idea why this could be happening? I assumed it might be driver related but he did DDU and the blank screen problem persists.
