Hello fellow pc enthusiests (waves). Anyway just here to check up this build.
This is my second pc build, though one can never be too cautious when it comes to building a decently powerful system such as this.
(yeah i don't really want to get the parts and find out it isn't as good as i once hoped -_-). Blah blah blah rambling on, bottom line is that i am just wondering is this all going to work the way it should?
Btw I could use some helpful input into what power supply i should use to best suit this system and if necessary should i get an 'aftermarket cpu cooler'. If so, what?
Here it is. The build :
Case : NZXT Phantom 410 Mid Tower Case White
CPU : AMD FX-8350 8 Core Processor
Motherboard : ASUS Sabertooth 990FX Motherboard R2.0
GPU : EVGA GeForce GTX 670 Superclocked+ 4GB
Memory : G.Skill Ares F3-1866C9Q-16GAB 16GB (4x4GB) DDR3
Powersupply : ???
After market CPU Cooler : ???
Anything Additional : Fans and what not? (120mm/140mm fan slots, Clearance for a 240mm dual radiator for water cooling solutions)
