Hey, I built my system a year ago and am now looking to upgrade with a 2nd Monitor.
The second monitor would not be used for gaming but media controls and watching youtube while playing on the primary screen.
my build : http://pcpartpicker.com/user/EvanFireheart/saved/Xw2
I don't need a huge second screen, around 15" would be perfect I think. If you have any good Ideas then please tell me.
Thankyou!
-evan
Warpig
September 17, 2013, 12:29am
4
This should fit the bill.
http://www.amazon.com/Acer-V173-DJOb-17-Inch-Monitor/dp/B008TYQI3C/ref=sr_1_1?s=pc&ie=UTF8&qid=1379377673&sr=1-1
You can get a 22" 1080p Monitor for $100 it will look a lot better siting next to your monitor than a 720p 15" and dosent take much gpu power to run if you are not gameing on the second monitor.
Allso those Hannspree (Hans G monitors) are good budget monitors i currently use a Hannspree HE225DPB 21.5" Monitor ($117.80)
Ew, it's a square. I'd go with something widescreen for watching YouTube.
My second monitor is an Asus 19" 1680x1050@60P, link: http://goo.gl/WWyxwV
