Made a $750 dollar system 2 years ago at 15 and at the time the future proofing seamed sound but now it is becoming a little outdated.
So confident in spending more money in a second build this is my current parts list http://pcpartpicker.com/p/VtbhvK there are plenty of questions which need asking as this is only my second build and my first with water cooling.
I understand I could go with an i5 and not come close to bottlenecking the gpu but the system is made in mind that in the future if it is needed I can set in a second 780 and run them in sli, (a more balanced gpu/cpu combo imo)
Firstly I hope to cool the gtx 780 with the Kraken g10 and the corsair h60 cpu closed loop system and the h100i to cool the cpu.
Im pretty sure a h100i would easily be able to handle a 4.6 to 4.7 overclock of the 4790k at the cpu is already at 4ghz however what do you think about the h60 for the cooling of the 780 which I hope to mildly overclock as well?
Secondly, on the list I'm dedicating around $200 of the build for water cooling the cpu and gpu, is there any custom water cooling kits which you could suggest which would be in the similar price range?
Understandably a custom water cooling loop is more difficult to assemble but If there is a proper custom substitute for the h100i,h60, and kraken g10 I would be all ears.
The psu is another point of worry as I know Corair is a very reputable power supply so when I saw a 80+ gold 750w for only $85 I was a little worried about proformance though Enthusiastic about the price.
750 watts will be overkill for the innitial build even with overclocking but a second 780 might require it.
Finally this pc is meant to primarily for gaming and multi-tasking so please comment if there would be changes or other info for such a build.
Finally overall suggestions would be greatly appreciated, I understand that there are a lot of people here who are MUCH more knowledgeable than I am when it comes to this.
Excited for my second build but not excited enough I'll run in blind as to aspects I'm not familiar with.
Thanks for any input- CallsignLOBO
