Dumitru here, young blood so to say, first post (big youtube fan!).
I am an civil engineer, young antrepreneour ( three emplyees), an architect and a services engineer alog with me.
I am planning on building a rendering pc for our projects (Vray). Seeing the mind-blowing (for me) work that you guys are doing with amd hardware, the builds and so on, I decided to ask your opinion, is my thinking ok on this build:
CASE: Corsair Carbide Air 540 Air in White
CPU: 2990WX Threadripper
CPU Cooler: Cooler Master Wraith Ripper
Motherboard: MSI X399 MEG Creation
PSU: Corsair CX750
RAM: G.Skill Aegis 3000Mhz CL16 64Gb
SSD: 2x Adata SU630
GPU: Gtx 1660Ti
STORAGE: NAS Synology 6Tb
I decided to go for a CPU rendering build because I can’t afford a similar performance GPU build, too expensive, and the precision is worse.
If you guys have any suggestions, I would be happy to read them, thank you!
Looks fine to me, assuming you made a typo with the mobo,
being X399.
Maybe if you could find some cl14 G.skill memory kits 3000mhz / 3200mhz,
something like TridentZ´s.
That might be worth it, if the price difference isnt that big.
Air cooling is tough on a 2990wx, but with a good airflow case like the Air 540 and great coolers like the Wraith Ripper or Dark Rock TR4 (my personal favorite), you should be good.
I personally would go with a better Power Supply like the Corsair RM750x, I don’t like cheaping out on the Power supply, and the RMx is a great unit with a bonus of being really quiet.
I really don’t like the Adata SU630 SSDs, combines all the negatives IMO. ADATA doesn’t have the greatest reliability record for their cheaper SSDs, QLC nand is still meh, and no DRAM buffer. Do yourself a favor and get something better like the Crucial MX500 at least. Even better is to splurge for an NVMe drive as well IMO, NVMe main drive + SSD storage drive is a nice setup to have!
The Asrock X399 Taichi is indeed a great board for the money.
However this particular board and many other TR gen1 boards are more suited towards,
the 180W tdp cpu’s like the 2950X.
This because the vrm is a bit limited on most gen 1 boards.
You could run a 2990WX on the Taichi and Professional gaming a like,
but you need to be sure that you got some decent airflow around the vrm area.
Otherwise the 2990WX will really push the vrm to its limits,
and the vrm will produce allot of heat.
This is one of the reasons why the Msi X399 MEG creation and the Asus Zenith Extreme Alpha are that expensive.
Because those are gen2 boards with upgraded vrm’s.
Those 2 particular boards are mainly ment for the 250W tdp sku’s like the 2970WX and 2990WX.
For the people that are not interested in those behemoth cpu’s,
But being fine with a 180W tdp cpu up to a 2950X.
Then it would be a waste to invest in those two expensive boards.
Because boards like the Asrock X399 Taichi etc would offer a decent value for money.
The Asus X399 Zenith Extreme (non alpha) technically has the same Vcore vrm as the Asrock Taichi.
However you can get an active vrm cooling kit with this particular gen1 board.
And this will help reduce powerstage / mosfet temperature significantly.
And there for the board could run a 2990WX with some overclocking.
Thank you, it was a mistype, I will look for better memory, from what I understand Ryzen architecture benefits substantialy from faster and tighter memmory
The VRM was my main reason for choosing the MEG, it seems to be a power delivery beast.
I am not a rich person, and I preffer to not risk in any way the safety of this investment. This is the reason I am avoiding AIO coolers, there is a terrifying video of BitWit Kyle on Yt with an AIO failure… Wraith Ripper seems to do the job, But I guess the Dark Rock 4 is more silent (having two fans that run slower).
And beeing limited by the cooling solution I am not planning on doing any overclocking, neither do I have the experience/skills needed.
Thank you verry much for your time and help, means a lot to me
