I honestly am not worried about getting 4 way sli working properly. If you look at what my main concern is… If i run even just 2 cards in the suggested configuration of slots 1 and 3, regular 2 card SLI of 2x 1080ti, I get random stutters, freezing and crashes. If i run with slots 1 and 2 instead, the issue doesn’t happen. This is 16x and 8x slot configurations, and the manual and all documentation from asus is saying slots 1 and 3 for 2x 16x slots is the suggested config, even in the bios. The only logical conclusion I can come up with is the Cross Die communication. I am just trying to figure out if this is a Zenith Extreme board issue (since i have tried with 1950x and 2990wx, as well as 2 gigabyte 1080 tis and 2 pny 1080tis, same issue) or X399 / TR in general issue. The odd thing is not all game freak out like this /exhibit this behavior. Call of Duty BO4 is the main one to do this. I have gotten other games to run without problem though, sometimes random stutters but nothing like B04(when using slot 1 and 3).
BO4 will run with all settings maxed out at 3440x1440 and be locking in between 170-200 fps when in slots 1/2 and struggle to run at 80-110 when in slots 1/3 and have stability issues.I have also tested with 8, 16 ,32 cores, SMT on and off, you name it, but if using those 2 slots issues happen. I have also run just a card in slot 1 or 3 without issue. So it could be cross Die / Infinity fabric issues.
I am trying to see if anyone else out there have had issues with running PCIe slots that are split die communicating.
As for the official support, Yes i know nvidia killed off support past 2x on pascal and newer. There are forums going over how to make it work (and when it does, is insane what it can do… but I am nowhere near getting that to work considering i cannot get a simple 2 way to work well if not configured with 1/2 or 3/4 slots).
Other things to note / share in case anyone decides to be crazy and go 4 gpus on a TR build:
In 3d mark tests, IF i have all 32 cores and SMT enabled, the graphics test scores drop considerably ( great results if set to 16 cores , or 32 cores with SMT disabled) with 4 way SLI. The score is not phased if actually disable SLI which i find strange. So perhaps the 4 cards are being utilized by the benchmarks without the need for the SLI settings. With all of the odd behaviors and things I have seen with this configuration I am guessing having multiple Die configuration and not being able to set to local mode for memory on the 2990wx is causing some performance issues. I have seen some pretty awesome performance boots with Dynamic local mode in many different applications but hasn’t resolved any issues with the 2x SLI setup (even the 1950x with the option to change between NUMA / UMA it never got rid of the issues)
I never did get these issues when I had 2x 1080ti in an x299 / i9 build or x99 and Xeon proc build , which is why all the changes and tests are making me think x399 / TR is the root of the odd performance hiccups, but surprised no one else has posted similar issues. I have not tried any different board than the Zenith Extreme though for my personal build, but have tried a different Zenith board.
I am sure many people are going to wonder why I even care if i can simply run 1/2 and 3/4 sli configurations, but I would like to diagnose the actual cause and also make sure I don’t have faulty hardware. The performance between 16x\16x and 16x\8x SLI shouldn’t be drastic, but would be nice to be able to get it running correctly if possible.
