Okay so as I have asked before I am looking at a new GPU to purchase, with the intention of getting a second one later on down the line, first let me outline my specs.
i5 2500 3.3Ghz (Non K), 8GB 1600Mhz RAM, G1 Sniper M3 LGA 1155, OCZ 750W Bronze 80+ PSU.
Okay so with that first off, after the first GPU what would I need to change to allow me to use two? I have a Fractal r4 case, so space and airflow is no major issue, and I can always set pressure to negative to keep the cards cool if need be.
Secondly, will my CPU bottle two of them? one I have no doubt it will do easily, but unsure about two, also what lanes should I have them in on my board, x16 and x8? which of course would run them at x8 together, but what performance would I loose between them?
I also would like a quiet card, a bit of noise I do not personally mind, I just dont want the thing to scream at me, or make my case a small oven, I hear the 290x do this, is this true?
I want to play at 1440p of course, the desktop will be at 1080p, but games will be of course at 1080p.
The game bundles also intrigue me, which would you personally go for?
Would I be better getting a bigger frame buffer? or stick at the 4GB standard?
Will the bus affect the speed overall? the 970 is 256, the 290x is 512.
Any other suggestions on why I should pick which card? the main use will be gaming.
Many thanks!
