Using Catalyst 13.11 beta v9.4 drivers for the 290X(ran at stock settings).Fraps used to check the FPS
CPU:4670K Stock clock
GPU:290X Stock
So here is my problem.Today i tested 3 games at 2560x1440.Crysis 2,RAGE and Borderlands 2 and in that order.
Crysis 2 and RAGE both ran maxed in everything but AA which i set to 2x as i didn't notice the difference between that and the higher options.I get 51-60 Fps in both.
Once Borderlands 2 got installed on steam i run it,change the resolution to 1440p,changed fps cap to unlimited and maxed everything except for ambient occlusion(turned it off as it lowers the fps quite noticeable) and PhysX on low and i saw that i only get 23-30 Fps.
Is this performance to be expected or could something be causing this?
