Ok so my brother brought a Gigabyte 290 for his pc i currently have a Powercolor 7870 and for some strange reason my little 7870 is kinda beating his card, I usually get 80-100 frames on PlanetSide2 on ultra and he gets around 70-90, What the hell is going on??
Not sure of whats going on, but i would be led to believe that my 290 (with all due respect to my Lil brother) would crush his 7870. I have installed all the drivers I don't believe the issue is heat. I am running a very old and slow HDD from a laptop i used to have eons ago but the HDD should not matter during game play so I don't think that's the issue.
That's pretty terrible, I have to be honest. The R9 290 is intended to be used at 1440p and upwards of that, and the 7870 really ought to be used on a 1080p monitor.
That aside, you will see performance differences when the volume of pixels changes. The more pixels on the panel, the more calculations have to be performed to shade each pixel. But I would imagine the 290 would perform faster than the given frame rate.
Your 290 should play 1080p no problem. So if you have a 1080p monitor, you could use that option. Honestly, I'd try running the game in 720p to see how it compares to the 7870.
I want and will be buying a better monitor, just as I want and will buy a new HDD and SSH, I have just finished building this PC and at the moment I just wanted to get it functional hence the use of a old HDD and Monitor. once I save up some more those will come. still shouldn't my performance be better anyway?
I have downloaded and installed all the MoBo drivers and I am running 13.12 for the GPU.
I am going to guess that you guys are running into a bottle neck of some sort because of the low resolution and high fps the 290 is not able to stretch its legs at 900p so the 7870 at 720p is near the same fps. Also last time I played planetside it was not that optimized and my friends computer with 7970 CF were not much ahead of my 660ti when we were both using i5 3570k cpu. It was not maxing out the cpu either.
