As the title says which is a better choice. I know the 290 is better but is the extra performance worth it for the money. I have seen the 290 comparable to the titan and other high end cards but is it necessary to improve gaming quality. I plan on playing on a single 1920 x 1080 so would the 280x be enough if so when does the 290 become needed to keep max settings for gaming will the 280x still be enough to run 3 screens or will the 290 begin to do what the 280x cannot?
The 290 is definitely worth the money as far as performance goes, problem is is that it's LOUD and it's HOT! Loud as in 40DBa in "quiet mode," 58 DBa in Uber mode. Hot as in 95 Celsius when under load, which can cause it to throttle. Only way to tame the noise and temperature of the card is by either water cooling it or by installing an Arctic Accelero Xtreme III on it. That would bring its price up to $475. Still a great price, but it's quite a bit of work.
All right I don't want to spend the money for water cooling right now so if the non reference cards don't drop before I see a sale on the 290 or just can't wait I'll get theArctic Accelero Xtreme III since I read its a good way to deal with the hot temps.
If its for 1080p single monitor, 280x is absolutely fine. Anything above however the 290 is a much better choice, although waiting for the aftermarket coolers is a good idea as suggested above.
