I am planning a build into the colossus micro ATX when it comes out though there is little information on compatibility. So here is my question considering the Prodigy M has similar if not the same space inside will a 280X fit into the system in stock or water cooled?
Just check the dimensions of the card, and the case then give the card a little clearance for cables.
