hi guys,
just a quick question. should i go for the 280 or the 270. the 270 is 160 euro's with bf4 50 euro. so it is 110 cuz i want bf4:) or the 280. the 280 isn't on the market now but i am waiting. i buy my pc in februari and i hope the 280 is 220 euro or less with bf4. i won't upgrade it for 3 years. i like games like bf4 but i don't run them on ultra. just 1080p with texture on ultra, but lightning on low and shadow low. does someone has a 270/270x 7870 with bf4? i don't know what kind of frames you get with the settings i prefer.
settings:
texture on ultra
texture filtering on ultra
lightning on low
effect on low
post proces quality on low
mesh on low/ ultra. don't know what it is but i believe it is smoke. ifso i prefer low
no aa.
scaling. 200% is nice but that's 4k. 100% is just fine.
i hope the 280 is a 7950 with the same amount of processers as a 7970 and a bit cheaper. 7950 is really expensive. there is are some cards cheaper but i don't want a club3d card or a xfx. club3d is bad cooling and the xfx has locked voltages.
oh and yes, i overclock.
i don't know if you care but my build that i am going to buy is:
fx 8320 (125 watt stock but i oc to 4.0-4.5ghz, 160 watt?)
asus m5a97 eve r2.0 ( 6+2 power phases 140 watt max, is that a problem?)
hyper 212 evo
fractal r4
crucial balistix 2x4gb 1.35volt 1600mhz cas 9 (oc to 2000 if i want with cas 8-8-8-24)
1tb barracude 7200rpm
cx 750 or the cx 600
i don't know if ddr4 is comming on feb but i don't care about it to much. ddr2 isn't that bad today. only good thing is lower nm but 2011-3 socket is gonna be expensive? socket 2011 is expensive. 20nm on gpu's is maybe a factor but i don't when it will come.
