I'm trying to decide on a 27" monitor. The two I have come up with are the Achieva Shimian for around $380, or the Ben Q GW2750HM for around $200. I feel ok about the Ben Q but it is a cheaper monitor, the Shimian has the resolution, and colors I want for my design work but it make me a little hesitant because mix reviews and dead pixels. I am probably being silly and just need to but one but tell me what you think.
take a look at asus 27" monitors, there under $300
I have 3 of them and there amazing for work flow- video and photo editing
Witch one I have found 3 good ones are these them.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236295
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236342
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236362
http://www.ebay.com/itm/Matte-FREE-EXPRESS-X-STAR-DP2710LED-27-2560x1440-Samsung-PLS-Panel-Monitor-/330932578190?pt=Computer_Monitors&hash=item4d0d1e678e
1440P for $300, nuff said. If you want more Logan even did a review on it.
https://www.youtube.com/watch?v=wlVbGcv0g-g
I saw that and I was putting in the same group as the shimian, What I was asking was should I get one of these cheaper Korean monitors, or a lower resolution one from the name brands.
i would definitely go with a Korean 1440P. For the price they are unparalleled. I would buy one in a heartbeat if my bank account allowed and my GPU had enough horsepower to run it. Logan mentioned in a comment that he has bought alot of these monitors and only one came with a dead pixel. The name brands probably have very similar factories and components. So I don't see how a korean monitor could kill you (unless it's north korean then you should worry)
Ok I you have convinced me I will go for the Korean and hope it's not from the north : )
Cool let me know how you like it!
+1 for korean monitor
I will I just got paid and I am ordering it, so I will more than likely post once I use it.
if you look for a monitor for design work, den please make sure its an AH-IPS. panel. 1440P would offcourse been nice.
