Hey guys, I've been finding it quite difficult to choose a monitor. I heard that 27 inch monitors aren't that good because they need a higher resolution. Should I buy a 27 inch 1080p or a 24 inch. I will mostly be using it for watching anime, movies and gaming.
Nope. I don't really know what 10 bit is a quick google search tells me it's to do with better colour representation, but I haven't come accross many anime that are in 10 bit apart from one piece. Would 10 bit have any affect on normal videos or would it only be better if the video itself was 10 bit?
If you are using as basically a TV, get the 27inch. If its main purpose is gaming, but you watch occasional movies and anime get a 24inch. I find 27inch pretty overwhelming for size when sitting so close to it.
Go for a 24" monitor. There's no point in getting a 27" unless you're getting a higher resolution like 2560x1440. The larger the screen, the lesser the pixel density, which is going to result in larger pixels and overall worse picture quality. 1080p is going to look a lot better on a 24" monitor.
24" and 27" monitors can stay at 1920x1080. Resolution is not an issue. If you have the money, a 27" monitor looks and feels a lot more than 3" inches larger. You will notice a difference larger than 3" when switching from 24" to 27".
