2560 x 1440 Monitor Issues
I need help picking a 2k monitor. I've heard that the Achieva Shimian has some I problems with customer service and dead pixels, but I don't want to fork over $1000. Can you give me suggestions on monitors or verify that the shimian will be fine?
Hi, I got the CrossOver 27 QED. It uses the same LG LED panels as the ones you mentioned, but perhaps at a different rated Hertz. CrossOver usually runs at 60 Hertz. It is good if your playing RTS games or looking for near perfect imaging and colors. But if your playing mostly on FPS games, it has quite a bit of ghosting effect which might irritate you. And if i am correct, you can request to pay more for them to check for dead pixels and colors before purchasing or just purchase those that are pixel perfect versions at a higher cost.
Heres the link:
http://www.overclock.net/t/1280755/review-tests-crossover-27q-led-p-pivot-edition-gallery-with-apple-cinema-display
Just my 2 cents. =) Happy hunting!
