I am building my new pc in the next few weeks and just wanted to make sure that all my parts will fit and the temps will be OK.
I7 6700k
h100i GTX
EVGA Z170 stinger
EVGA 980 ti
16gb ddr4
EVGA 650w
500gb ssd
250d
I7 6700k
h100i GTX
EVGA Z170 stinger
EVGA 980 ti
16gb ddr4
EVGA 650w
500gb ssd
250d
should be fine, will be tight though
Is the GPU internal exhaust like the ACX or external like reference?
It makes a difference.
I haven't decided what would you recommend, I can afford either?
Thanks for replying
In my opinion yer probably gonna want a cooler that exhausts out of the case, like the reference style coolers, rather than inside, like ACX and whatnot.
In small cases, like the Corsair 250D, if the card exhausts internally it can end up recirculating the hot air over and over, causing everything inside to heat up more. If it exhausts externally like the reference design, it will blow the hot air out the back of the case so there's less heat build up.
Thanks for the reply, reference it is then, not all bad as I think the 980 ti reference cooler looks amazing
