2500 SEK upgrade ($400)
Hello Tek Syndicate communitaaaay
So I haven't really upgraded anything more than my CPU cooler and GPU for a long time.
What I'd like to upgrade the most is my processor and I'd like to overclock it aswell.
My current specs:
Motherboard: Asus P5N-D, nForce-750i SLI, Socket-775 (This is definitely the most crucial part since it's socket 775)
Powersupply: Corsair Powersupply 650W (works very well!)
CPU: Intel Core 2 Duo E8400 3.0GHz (Currently overclocked to 4.0GHz without problems)
RAM: OCZ Reaper DDR2 PC8500 4GB 1066Mhz (Would like to upgrade this aswell to something like Corsair Vengeance 8GB 1600mhz)
GPU: Gigabyte Radeon HD 7870 2GB GDDR5 Windforce 3X (my newest addition, perfect as it is)
So what I want to upgrade is my motherboard, processor and RAM. Like I said before I want to overclock my processor. So I want to pick either the i5 2500k or the i5 3570k.
My cooler is a NH-U9B SE2
This one cools my E8400 clocked at 4 GHz really nicely. About a peak of 65c in full load.
4.00GHz @ 1.39V to be specific, and that's a high voltage. So I think I could do some good clocking with either one of the processors above.
Also, how much would I be able to overclock these processors that I mentioned?
Thanks in advance!
With sandy and ivy now old news you should be able to pick up a sweet deal maybe 2nd hand. Geez for $400 you could score a 2700k with a ROG board + ram if you look hard enough.
Buying those older parts new though is going to be costly.
That cooler will allow you to oc a sandy cpu quite high, ivy a heap less and if you bought a new haswell setup well yeah, things would get hot pretty quick.
If you wanted to grab (a new) really fun overclocking package perhaps its worth looking at going to AMD - a 8350 + nice 990fx board + ram would still be around $400 and be covered by warranty.
http://pcpartpicker.com/user/deejeta/saved/2ul1
If you are in OZ i could point you to a great forum where heaps of good gear gets sold, otherwise maybe have a gander at the for sale section here at the Tek >>https://teksyndicate.com/forum/buysaletrade
Hope this has helped somewhat.
