Hi,
I'm from Finland and i want your opinion about my setup that i'm going to buy.
Things that i already have: HX1000W from old system.
And i'm going to change those Defile XL R2 coolers to Noctua ones for ultimate quiet.
Also Maximus VI Formula for the badass looks and soundcard features + quality i get with Asus products.
I'm not so sure about the monitor... I will read some more information about that. Also Corsair 16GB Dominator Platinium for quality and exelent look of it.
What do you guys think about my setup overall?
(sorry for Finnish language, if you dont understand something i will translate that for you)
What i think? it's expensive x) but wonderful in it's own right. I don't have many issues with what you've picked. You can save some money on the memory, well a lot, you can get a couple of Corsair Vengeance 2133 for 100€ less, but they're not as cool i guess. The FPS difference you gain from memory with a dedicated graphics card are minimal.
The motherboard is supposed to be watercooled, but it seems that it will not overheat without watercooling either according to some people, but that's something to consider.
Now that monitor. The name PA stands for Pro Art and is as the name suggests made for professional use and that's where a lot of the price has gone into such as monitor features and individual color calibration. If you're a gaming kinda guy and not much into working on your PC you could look for a 1920x1080 monitor with 144hz they won't have the stunning color display of an IPS panel, but the extra frequency for gaming is so amazing. It'll make a 60 hz monitor seem to stutter.
But if you want that extra vertical space and great color quality instead it's up to you, 16:10 is a PC resolution after all and it's a very good monitor. but you might pay for features you'll never use.
You can get in finland vengeanse 16gb for around 180 euros. But tho me the extra price difference can be justified just by looking those sexy platinium sticks.
Also i was wondering for a "gaming-grade" monitor for a while but decided to go whit ips-panel. Reason for that is that i respect more deeply and natual colours in gaming. And example linus did told thst he wasnt regonizing any input lag or ghosting whit this monitor... So i'm curious to see what other people think about this monitor in gaming who allready has it, do you see any ghosting/input lag?
And the formula can be watercooled, alltrough is not must. Its perfectly fine with air. + that sexy noctua will blow some air into it so no worry about that.
i am from finland too, this would be the way to go if i were you
Also i would add a couple of LED strips to make the system look absolutely beautiful, since the 350D Case has a nice window on the side.
This sytem would perform better than yours, since the two GTX 780 perform better than a single GTX 780ti, but it is up to you, if you want SLI or single GPU. Your build is also good, but this is what i would build :)
builds look cool, but honnestly, i realy still dont get why people get so stunning at a GTX780 Ti the card just isnt worth its price point at all. especialy if you wanne game on single monitor setup, its totaly not worth it. GTX780 or R9-290 non reference are just better value for monny cards.In the Netherlands i can buy a Sapphire R9-290 Tri X for arround €400-€430. its cheaper then a GTX780, but it performs better in "most" games.. its even not far behind a 780ti
for the rest the parts are awesome.
About a monitor take a look at AH-ips panels, most brands will use LG AH-ips panels inside, thease panels are awesome. Asus LG Dell are realy decent.
It's only 6 ms delay, don't think ghosting can be measured below 8 ms (just what comes to my mind). As for the noctua, while they make up in performance they lack in cosmetics. Most would argue they're not very pretty and if you do want a show off system you might wanna get the Be Quiet! Silent Wings instead, or/and their Dark Rock 2 heatsink with that. They are very quiet and will look amazing in a windowed case. I might be biased cause i have Be Quiet coolings myself x) By the way...Optical drive?
If you're gonna SLI asus gtx 780s you should probably go for an asus maximus VI HERO instead, stacking 2 cards ontop one another is not really that good with open air designed cooling solutions...*not blowers* x)
That monitor is probably not that great since it only has HDMI and VGA connectors and suspiciously cheap :P
Thank you very much for all the answers!
To me, if the next 8xx-series will totally blow the ti out of water, i will sell my TI and i can get from that ASUS more value than the normal 780. Also i do have 2 extra monitors that i will plug in into my setup. In battlefield 4 the extra monitors are useless, but example DIRT 3 (which i love with my G27 btw) the extra juice from TI is justified with 3-monitors. ps. i just love to say to my friends that i have better graphics card than they have… And only that is worth the extra 200 euros
Also for the hoocee, i have had around 5-6 years SLI-setup in my pc. And i will never ever ever ever go back to SLI unti nvidia/amd fixes micro-stuttering and SLI-profiles all together. Maybe not now it wont be problem but when games go more demanding the micro-stuttering does become issue
1TB i don’t need cause of NAS-setup.
350D is way more louder than the fractal and also the Noctua fans (even though the looks of it might be ugly to some, i personally have become to like those overtime) Noctuas quieter than corsairs, i think…? And if i add lighting in my case, my girlfriend will totally rip my balls of from my body. Cause now in my Antec 1200 and 780i, the blue light from the motherboard when system is turned off, brights like a fucking second sun at night and lights up the entire room whit blue annoying light… So i rather save my balls.
Liguid cooling i will not touch, cause of the leak issues and Noctuas actually does perform surprisingly well compared to Corsairs.
Asus Formula for the onboard sound and also for the durability that he “armor” creates, and i sure does look sexy as fuck. (Many other disagree with me on this)
In DDR3 sticks, the price difference is only 57€ and the extra durability, style and look brings. Is jutified to me.
And the what goes for the monitor, oh my god i love my old HP extra 1200 vs 1080 pixels… quick google-search does say that the more expensive ASUS does have better color. And the fact that you can get IPS for 250€ does worry me a bit that to gain that value, where does the price drop come from…? But i’m VERY intrested to read what other people think about that cheper Asus…
ps. i do not understand why does it just keeps shrinking it down to one big line of text, all through i separate them in the original text. And don't forget that i will be buying new Ikea Markus-chair ;). Cause i hate when i sit on my computer and my ass gets numb
Optical drive is useless! Never used it in yeaaaars. Just plug my bootable-usb with windows in it and good to go!
good that you've got your mind set. If "Cheaper ASUS" is the motherboard you're thinking of, then i can tell you that a maximus VI HERO is a really good motherboard, and one of the first motherboards i've had that my ears won't break from having my headset plugged in the front jack, and my microphone sounding good through VoIP. They seem to have the same 8 channel supreme FX audio chip on board.
The one thing i'm missing from the maximus VI HERO board is more 4 pin fan connectors. There's only 3 slots + 2 for CPU fans, while it's easily resolved with a 4pin fan to molex adapter it's something to consider.
The spacing won't work if you shift+enter, i had to deal with that as well when i first got here but with practice it'll go away! x)
I've got a markus chair of my own, it's pretty nice although it's old. Keep the hex key though as some screws will have to be tightened every 8 or so months, mainly arm and back support.
