Hello,
I am going to be building my first gaming computer, I have done research over the past few months, reading and posting things on forums and watching youtube videos, newegging, etc. and I have a build that I am pretty content with and would like to know your opinions on it.
One thing I am not sure about is the case however. I am torn between a NZXT Switch 810 and a Silverstone TJ11. What are some of the things you guys like about one case or the other. Obviously going with the Switch 810 would save me $400 however, if I want to go with the TJ11, it has a infinite amount of modding options, future watercooling, room for anything, and longevity because of its completely aluminum constructing with multiple layers. Both cases would house a air cooling setup for the time being since my budge cannot support purchasing a water cooling setup currently and I personally don't feel very confident doing it myself, but we will see about that in the future. The Switch 810 has room for 11 fans and is really good for air cooling. The TJ11 has the 90 degreen rotated Motherboard Tray which apparently helps cooling, and there is a ton of ventilation at the top which would help with getting the heat out. It would also, like I said, be really good for watercooling in the future if I decide to go down that route.
Anyway, here are the specs of my system which is going to be a system that I will upgrade rather than build a whole new system. Hopefully want the current parts to last 1-2 years without a change (maybe get another graphics card):
Case: Switch 810 or TJ11
CPU: Intel 3770k 3.5GHz (Will probably overclock to over 4GHz).
CPU Cooler: H80 or H100 (Would perfer to go with the H100 because of the dual rad meaning more surface area however, the TJ11 does not support the H100 so I would have to go with a H80 in that case, however the Switch 810 does so it would be a H100 in that case)
PSU: CORSAIR HX1050W (I could go with a 850 and save $40, however I think that it is good to go with a 1050W so in the future, if I decided to put more power hungry hardware in like another GPU then why not have that extra headroom.
Motherboard: ASUS Maximus V Formula (No ThunderFX) (This is one thing I am not sure about and would probably be an easy question to answer, would this motherboard fit in the TJ11? The TJ11 fits ATX and XL-ATX and this motherboard is E-ATX. The motherboard has screw placements in the usual ATX location, I am just worried that, even though the case says that it can fit sizes much bigger than this motherboard, something will be wrong. If someone could clear that up for me that would be amazing)
RAM: Corsair Vengeance 16GB (2X8GB)
GPU: EVGA GTX 670 FTW (I have actually purchased this card, and I think it was a good choice because it is the nice middle point of price-performance. And I could always buy another and get even better performance when games start getting a little more demanding than a single card can handle, but that will probably be a while. I can still however return it if it really was mistake for whatever reason, it is still in the shrink wrap and I have the reciept).
SSD: Mushkin Enhanced Chronos Deluxe 240GB Boot/Programs Drive (I want to keep this computer clean (aka not have a million un-needed programs on it) so I am going with the 240GB SSD for both Windows and all of my programs) because the price on newegg has it at around $160 which is an amazing $/GB and the reviews make it sound like a good SSD).
HDD: x2 Western Digital Caviar Black 1TB 7200RPM (The reason I am going with 2 of these drives is because this is a gaming computer so I want to have my games on one drive without having to uninstall them. And the other drive will hold FRAPS files and any other video files for Youtube. The drives will not be in any sort of RAID configuration).
Extras:
Fans: COUGAR CF-V14H (I really like the look of these fans and I think the orange would really compliment the black Switch 810. I would only need to buy fans if I am going with the Switch 810 since the Tj11 comes with fans preinstalled.
Fan Controller: Sunbeam PL-RS-6 Rheosmart 6 Fan Controller (I would buy two of these to go in the Switch 810 because there are room for 11 fans and 2x6=12 which is just one more than I would need which is perfect. I probably won't need them to go in the TJ11 because the two 180MM fans have build in high and low controllers in the top of the case and there is no point in buying a whole controller to just control a single 120MM fan).
If you read to the end I congradulate you and hope you can give me any suggestions and answer some of the questions I had above.
