Hello to all. I wish to build a $2500 (give or take) PC for gaming & Video Editing (as well as data encoding) in the next few days. I already made a parts list that I think is pretty solid for the price, however, if you guys could tell me a way to save money while keep the same general performance, or instead spend a little bit more to get a substancial boost in performance it would be very much appreciated. General comments on my part selection are helpful as well.
Parts List
Main
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor
ASUS Maximus V FORMULA LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
XFX PRO850W XXX Edition Semi-Modular 80 Plus Silver Certified 850 Watt Active PFC Power Supply
2 X SAPPHIRE 100351SR Radeon HD 7970 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP in Crossfire
Western Digital Caviar Black WDBAAZ0020HNC-NRSN 2TB 7200 RPM SATA 3.5" Internal Hard Drive
COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1) Black Steel / Plastic ATX Full Tower Computer Case
2 X Kingston HyperX 3K SH103S3/120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) in RAID 0
CORSAIR Hydro Series H100i Water Cooler
Mushkin Enhanced Blackline 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory
Additionals
2 X Corsair Air Series AF120 Performance Edition CO-9050004-WW 120mm Twin Pack High Airflow Case Fan
Corsair Air Series SP120 High Performance Edition CO-9050008-WW 120mm Twin Pack High Static Pressure Case Fan
Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM
NZXT CB-LED10-RD Sleeved LED Kit - Red, 1 m
StarTech Model PCIEX68ADAP 6" PCI Express 6 pin to 8 pin Power Adapter Cable F-M
Thanks :D
