Gigabyte ga-ab350m gaming 3
Windows 10 home
I have a new ryzen 2400g build a for some reason the cpu clock speed jumps around. I tried changing the power plan to high performance. has little affect. Ideas?
Windows 10 home
They do that as needed by the OS. I can watch it happen on my 1700X, 2400G, the Xeon on my workstation at work, etc.
What software are you using to monitor the CPU?
Just task manager. On my Intel box clock stays pretty fixed.
Absolutely nothing wrong with that… You don’t always run when you just need to walk somewhere, right?
If the CPU needs more speed it increases it’s clockspeed. Those changes happen constantly. More often than you think…
Thanks for the replies… Why does my Intel cpu not do this?
The ryzen is brand new pumped full of sense technologies and boost technologies and what not.
Intel may also boost, but not as often and not as granular…
I believe OP just wants it to stay at max speed.
I believe somewhere in Windows there is a min ghz setting. Expressed as a percentage. Once set to 100% the clock speed will be at 100%. I don’t know if setting the Powerplan to high performance does this.
The thing is, you don’t need it at 100% constantly.
I want it.
Could you find out out? I missed with the power plan state set, min to 100%, max 100%
I believe what you did was what I was talking about.
I’ll see if there are other things you could try.
This also may be motherboard related. What’s your motherboard?
I’ll see what I can do
I did try a few things in the bios.
What things did you try?
And cool and quiet disabled in bios. Changed power plan. Reinstalled win10. Tried a couple of verisons of amd chipset drivers.
When I have my 1700X on an OC it still shows the clock speed jumping around.
[https://www.tenforums.com/tutorials/95574-change-maximum-processor-frequency-windows-10-a.html] would option 2 work? Is says maximum, but I really want the min to be equal to max.
