230 mm fans that are not bitfen
All i can find is bitfen 230mm . Anyone have a idea where i can find alternatives in the US
Do you have something against those fans?
If you want different color choices or whatever, here's a good link.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=36_327_1134
I'm not sure anyone else makes them. At least, not anyone with any quality.
Thanks , just looking for options .
http://www.overclockers.co.uk/showproduct.php?prodid=FG-065-AK&groupid=701&catid=2331&subcat=2335
http://www.amazon.co.uk/Thermaltake-23cm-LED-Fan-Blue/dp/B004AM2VGA
Sorry for the UK link's but might help you refine your search a bit.
Ya , already looked at the uk options . Which are by far better greater than the US options. But shipping pretty much kills it as a option .
