2133MHz RAM on FX-4350, noob question
Yeah that's it...How do I do this? AMD says the chip officially supports up to 1866MHz but since I am a genius I know that overclocking exists *wink.
   Unfortunately I am an absolute noob, I know my motherboard supports 2133MHz RAM via overclock, but what do I actually have to do to make it run? Will I need anything better than the stock cooler? Thanks in advance.
I may remember this wring but I think Logan said in a video that the APUs can get to 2133 with no problem. Sidenote: where did your username come from?
You're right except, the FX-4350 is not an APU! Even though some APUs have Piledriver cores (trinity for example).
My username came off boredom when I was studying electromagnetism for a physics exam. They said I could be anything, so I decided to be a differential operator XD
you do it through the motherboard's bios. what mother board do you have?
It is an ASUS AM3+ M5A97 EVO R2.0
Go to advanced options in the BIOS > click/navigate to Ai Tweaker > Find the DRAM frequency > click to bring up drop-down menu of choices for frequency > choose 2133 > save and apply settings > restart > check to make sure its working right (use memtest86+ or I guess you could use a "Blend" setting on prime95 and see if you get calculation errors, not sure though)
what ram did you get? it might contain xmp profiles that you can load the factory settings for the RAM into the bios.
http://www.prokoo.com/geil-2x2gbpc317000-2133mhz-corsa-10111130-p-71671.html    This is the RAM I got
It looks like it does have XMP profiles. You could still follow what I outline above, it'll work the same. If I remember correctly (I'm not at my computer to check my BIOS since I own the R2, not Evo R2) under your choices for the first option in Ai Tweaker will be "Auto, Manual, D.O.C.P." D.O.C.P. will make the board attempt to interpret the intel XMP profiles into something that AMD will recognize. People have said it doesn't always get it exactly right, but that is an option if you want to try.
Also, if you do it as I outlined above, you'll want to check the timings of the ram to make sure its the 10-11-11-30 that the ram is speced for. After all the cpu options in Ai Tweaker you'll see options for adjusting the DRAM, click there and see what the timings are at. The board may be running it at slower timings (higher numbers) right now due to defaults. I can't explain the timing changes very well(I myself have a little issue with understanding them), so you may want to have a whole other post if the motherboard isn't reading in the right timings.
If you want 2133 mhz, do what kmcc said. It's the easiest way to get a safe overclock. After you get a working baseline from the auto settings, and you validate that it works with a mem test, you can tighten up the timings a bit manually. However, if you're only gaming with this rig, i'd keep the ram speed at 1866 with tighter timings.
