TL:DR How is the support in games for 21:9 resolutions?
I'm still rocking a 1680x1050 monitor from 2006 and I think it's about time for me to upgrade. I play racing games sometimes and in racing games it's beneficial to have peripheral vision and to have the ability to look from side to side without grabbing the mouse to move the camera. So I've been looking at 21:9 monitors and thought that would be a good solution for me, but I'm worried that games won't support those resolutions and will therefore be stretched out and distorted. Or have they already though about this and implemented a way to display something at 1920x1080 on these screens by only using a portion of it?
I know a BenQ XL2420T and can emulate different 4:3 and 16:10 resolutions, other than the native 16:9. But i never use it. In my opinion get a 16:10 1920x1200 or 16:9 1920x1080 monitor or why not 2560x1440 if your wallet and graphics card can handle it. you'll get used to the new resolutions really fast and they look a lot sharper than your current system of 1680x1050.
21:9 is absurdly wide and unmanagable if you wanna play any FPS or fast paced games cause so much of the screen is in the peripheral vision. I would advise against getting such monitor for gaming.
i have a 21:9 monitor and i actually really like it. i don't game as often as i used to but when i do it's mostly MMORPG's or something like torchlight 2. all the games i play seem to support it. Most of the time i have a bunch of web pages open so i can have two side by side with no scroll bar from left to right so that's nice as well. if i remember correctly skyrim looked a little weird on it. but i didn't play with it much so i could be wrong.
Don't get a 21:9 monitor for gaming. They're supposed to be used by editors for to side by side 1080p displays. If you are a gamer and in the price range for one of these just get a 1440p display. Much better to game on. :)
these monitors aren't supposed to be used by editors. they just happen to work well for that. they are supposed to be used for what ever you want to display on them. i happen to enjoy the wide aspect ratio. but as pawmaniac said it's all a matter of opinion. get whats in your budget and do a little research before you spend the cash. also make sure you have enough GPU power to run games at the resolution your new monitor will be running at native.
21:9 is actually intended for film editing. Idk if you have paid any attention to the newer movies but they are using 21:9 ratio now, it's starting to become more frequent on movies. Maybe we might go 21:9 in the near future because people tend to like wider angles more and more.
I would suggest 1440p monitors over 21:9 because you get overall better performance for the value. 21:9 is quite a premium pricce.
who fucking cares what it's intended for. stop being sheep. if you like the 21:9 for whatever reason, then use it! i for one, love how it looks and the desktop space it provides is amazing. will be my next monitor purchase. shit is so baller!!!!!!!!!!!!!!!!!!!!
