20lb-single arm monitor mount
Does this thing exist? Wall mounts don’t count, just desk clamp.
25lbs
I had the Amazon one and found it mediocre. It didn’t have enough vertical lift, even after adding extension arms. Kind of wobbly too.
I would go with this one if I did it over:
http://ergotechgroup.com/freedom-arms.html
You think i could stick a 43" panel on that?
“Screen of any size within weight range”
I will buy that arm in the near future and would be really sceptical about monitor arms not fully metal and below 100$/€. It’s just anecdotal but a friend of my was so proud of his 4k Screen on his “super heavy duty monitor arms”… last 2-3 weeks and then one arm just broke and the screen was damaged. He RMA the screen because he had some additional warranty on it but… you dont cheap out on stuff where your screens hang on, that’s how you lose money for sure.
