To make things easier around here just include some extra info so we can tailor you better.
OK so I have AMD FX-6300, ASUS M5A97, tried GPU passthrough with GTX 1050 and was able to get into a game but the mouse was not cooperating. I was using barrier for mouse/kb sharing. Anyway I wasn’t able to get it sorted and rage quit.
It’s tax season and I am able to build a new PC. I use Linux daily and when the game I was playing with friends dropped Linux support (Rust), so I bought another ssd and installed Windows on it to be able to continue playing with my friends. I haven’t played Rust in over 4 months because I hate rebooting into windows.
I want to build a new PC specifically for being able to have a Windows VM I can play my steam games in. With that said…
- Budget. How much are you willing to spend?
$1500 - Where do you live (what country, don’t post specific details), and what currency do you use?
US USD$ - Is there a retailer you prefer?
Nope - Do you need or already have peripherals? (this can add to costs)
I have monitor, kb, mouse, headphones, etc. - What will you be using your Glorious computer for? Gaming? Rendering? Mix of both? Or is this a home media PC or Steam Box?
I will be using as my daily driver, and gaming in a Windows vm - Do you overclock or want to get into overclocking?
NO - Do you plan on going for custom water-cooling now, or in the future?
I plan on getting one of the closed loop pre-built water coolers - Operating System. Do you need a new one?
NO
If you Game-
- What kind of settings do you like or what FPS do you want to play at?
As long as it’s playable. - What resolution will you be playing at? //or would like to play at.
1920x1080 - What kind of games do you like to play?
FPS survival, CS:GO, Rust, 7 Days to Die, etc. - What specific game will you be playing (if you really only play one)
If you Render or Edit things-
Nope
So I have two pcpartpicker lists and I’m wondering if anyone knows of any issues with either list, if these will work for my use case (IOMMU groups). Any suggestions, warnings, etc.
pcpartpicker[DOT]com/list/bvxH8M
AND
pcpartpicker[DOT]com/list/NnZvq3
Sorry for the URLs, I can’t post links.
Thanks all,
-BB
