2015 to 2016 Yearbook - Post your CPU, GPU, and Idle Temperatures
I noticed a thread in the CPU section from 2013 and after getting to the 60th post and noticing I hadn't even gotten close to the bottom I figured I would start a fresh thread for 1 year (it only makes sense).
Hopefully we can all consider making a new thread at the end of next year so we can continue the trend year by year.
i5 4690 + HD 7950
Added load temps...
FX 8350 + R9 280x
I have a few computers I can post I guess :P
Streaming Desktop / Main Desktop: CPU - AMD Phenom Ii Black Edition HD HX 955 X4 OC'd to 3.4 GHZ avg temp idle is 35 C at load in game and streaming 50 - 55C and only gaming 45 - 48C
GPU: R7 250X but I don't know the temp.
Laptop 1: Asus G50Vt: CPU: Core 2 Duo Idle 40C load in game w/ music is 56 - 65C and GPU is Nv 9800 GT.
Laptop 2: Lenovo B575: CPU: AMD E2 Vision E-450 GSE Idle temp is about 45 and under load even in minecraft is 60 - 67C and GPU is an HD Radeon 6320M no clue on temps.
Laptop 3: Acer KAV10 D150: CPU is an Intel Atom N250 (I think, if I remember correctly) and it is ALWAYS at 60C or above. GPU is an intel GMA975.
Laptop 4: IBM 600X revision E: Pentium 3 MX averaging at about 40C idle and under load (text editor and terminal open at the same time or just a browser open) it can get up to 50C.
Laptop 5: Apple powerbook 5'7: CPU is PPC Gen 4 7450ER and at idle it stays at about 45 - 50C and under load at 60C and GPU is ati Radeon 9700M Pro
Laptop 6: Apple iBook 4'4: CPU is a PowerPC Gen 4 7450 and it always stays at 47C GPU is an ATI 9200M Pro which is essentially a 9700 Pro for smaller displays.
Fun stuff
Tweaked my fan speed and layout a bit more.
I was able to achieve a pretty silent PC from 2+ feet away away. I have to literally put my ear 1 ft or less from the pc to hear any fan noise. And even then, it's barely audible.
All of my case fans are running at less than 700 RPM each. 12 fans total.
GPU idles in the mid 30c and gets up to the mid 40c at full load. (stock clocks)
CPU idles in the low 30c and gets up to 60c at full load. Running at the stock 4.4ghz turbo @ 1.10v (I did run it fine at 1.088v. Passed several hours of Aida64)
Power consumption: 130w idle, 260w gaming, 380w full load.
Full Specs:
Corsair Carbide Air 240 (Black)
i7 4790k @ [email protected] (sometimes 4.8ghz @1.29v) (Cooled by: Corsair h100i+4x Corsair SP120's in push/pull)
Asus Maximus VI Gene
MSI R9 280x (cooled by NZXT Kraken G10/Antec Kuhler 620 + 2x Corsair SP120's in push/pull)
16gb Corsair Vengeance 1600mhz
2x Crucial MX100 SSDs 128gb/256gb
Seasonic SS-850KM3 850w 80+ Gold
2x Corsair SP120's as exhaust fans
2x 80mm Arctic fans as intakes in the back (painted black)
1x 92mm Cooler master fan at the bottom for additional GPU cooling.
Modified NZXT Hue RGB controller
Pics:
The whole PC
The 120mm GPU radiator in the back
All Temps are with bone stock cooling inside an NZXT H230 (think Fractal R4) "silent" case. There is no aftermarket cooling. Ambient is about 68 degrees F (20C) No overclocking on 8320 or 380
case has 2 case fans; one in front, one exhaust. NOTE: temps went down about 1C with front door open. Not enough of a difference to screenshot.
Sure. CPU is a little warm. I should probably get rid of this old H55.
[a@jupiter ~]$ sensors
radeon-pci-0100
Adapter: PCI adapter
temp1:        +33.0°C  (crit = +120.0°C, hyst = +90.0°C)
acpitz-virtual-0
Adapter: Virtual device
temp1:        +27.8°C  (crit = +105.0°C)
temp2:        +29.8°C  (crit = +105.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +40.0°C  (high = +80.0°C, crit = +100.0°C)
Core 0:         +36.0°C  (high = +80.0°C, crit = +100.0°C)
Core 1:         +40.0°C  (high = +80.0°C, crit = +100.0°C)
Core 2:         +33.0°C  (high = +80.0°C, crit = +100.0°C)
Core 3:         +36.0°C  (high = +80.0°C, crit = +100.0°C)
[a@jupiter ~]$ uname -a
Linux jupiter 4.2.3-1-ARCH #1 SMP PREEMPT Sat Oct 3 18:52:50 CEST 2015 x86_64 GNU/Linux
[a@jupiter ~]$ uptime
 22:26:32 up  4:39,  3 users,  load average: 0.22, 0.38, 0.38
